Did ya Know
Recently found out that if you have a MSD ignition system you should not use a degree'd timing light. As per MSD you get false readings. The impulses sent by the box vs they circuitry in the light give you false readings. MSD says you should use a plain Jane timing light with a degree'd balancer or a timing tape. Just FYI.
Thanks for the tip. I'm going to try and get things wrapped up today, fire it up and set everything.
Good luck. Nice feeling when you fire it up for the first time. :D
