Driver restraint system
From the NHRA site
Effective Jan. 1, 2005, Y-type driver restraint system was no longer certifiable under the SFI Spec 16.1. However, existing Y-type belts with current dates of manufacture may be used until its two-year expiration period, which after that expiration date, the Y-type driver restraint system will not be certified with an SFI specification. Racers and technical officials should be aware that V-type harnesses are certifiable to SFI Spec 16.1. There has been some confusion regarding the difference between Y-types and V-types. A Y-type harness consists of a single strap of webbing ending in a single attachment point while a V-type harness also has a single end attachment, but it is a continuous length of webbing that loops through the end hardware and over both shoulders, effectively providing a double belt. If you have any further questions, contact your Division Technical Director or the NHRA Technical Department. Below, the Y-type and V-type harnesses are illustrated. http://www.nhra.com/2005/images/news.../harnesses.jpg |
Yeah, I saw that. Mine was new last year. I will have to change to V next time.
Mine was new last year also, but mine are the V type.
Thanks for the heads up. |
