Gear ratio Question
I need a recomendation on which gears to put in the Demon.
Last time out with the car I was shifting at 6800 rpm, but crossing the line at around 6200rpm. 340, 13-1comp, .530 solid cam,850 holley, 4500 converter, 4:10 gears, 27.8"tires (325x50x15's) Should I go with the 4:88's, the 4:56's or stay with the 4:10's. I have all three. the 4:10's are on a spool and the other's are limited slip. Suggestions,comments? :-k |
I believe you go through the traps + 200 rpm per gear size up .
Let's see, that's
4:11= 6200rpm 4:30= 6400rpm 4:56= 6600rpm 4:88= 6800rpm 4:88 work out to be close that way also. :-k |
Let's see, that's
4:11= 6200rpm 4:30= 6400rpm 4:56= 6600rpm 4:88= 6800rpm 4:88 work out to be close that way also. :-k Are you pulling hard at those rpm's? :-k |
I ran the combo through Desktop dyno2000 and the hp should peak around 6500.
It didn't feel like it dropped any power when I ran it all the way to the rev limmiter at 7000. I was real slow pulling the shifter on that one. But that's the 12.60 run. |
