Oil Changes
How often do you change your oil and filter?
When at the track do you change your oil every run, every other, after a full day of racing? |
I change mine after 2 trips to the track. It gets a little pricey using Mobil1 but I like the stuff. I use cheap NAPA oil filters, since I change them with every oil change.
BTW, while we're on oil, last time I raced I only put 6qts in a 7qt pan and my ET improved. I do use a windage tray but no crank scraper. |
Dan I understand that just because it says 7 qt it still only needs
enough oil to cover the pick up. May be good with 5 qts. By the way the Napa gold series is a pretty good filter! |
I change the motor oil and filter every 25 - 30 runs. I do the trans filter and fluid at the same amount of runs, and adjust the bands. The trans is a Cope Racing Trans, 727 rollerized , with billet aluminium front drum
Yeah, Tony, I hear ya. Good point.
So, are you gearing-up (no pun intended) for the season? I got a few things to do with the car, but it's so damn difficult to think about working on it in this weather. |
During the season I change mine pretty often, not on any set schedule. At least once a month. If I go out every weekend during a month I may do it twice, but that hasn't happened in a few years.
I've been changing it after every second trip to the track. Comes to every two miles I think :lol: .
Dan the car should go in the shop next saturday. Too cold out there to think about it. Took her out for a ride today. Terrorized the neighborhood for a little while. Can't wait to see what the gearing and the shifter do! 8-[ |
for a little while. Can't wait to see what the gearing and the shifter do! 8-[ You'll love the new gears by the way. :mrgreen: |
Originally Posted by fastbackcuda
I took mine out the other day. Only terrorized myslef. I ended up on a big snow covered hill. Note to self. Dont drive car on streets you dont know yet.
:lol: :lol: :lol:
For the record my street didnt have any snow on it and this on was fine till I got to the hill with no place to turn around. :mrgreen:
No I drove down a big snow covered hill.
:shock:
Tony, what gears do you have now and what ones are you going to?
Are you going to start the season off with the drag radials or slicks? |
Dan, I'm going from3:91's to 4:31's.
Haven't decided yet on the slicks vs the drag radials yet. Drag radials were not spinning last time out. The suckers really bite since I screwed them down and lowered the a/p. |
