Looking for brake pads and shoe recommendations
Looking for brake pads and shoe recommendations.
I’m re-doing the brakes on my 82GT, nothing exotic upgraded the fronts to 11” rotors with 73mm calibers rears are stock this is going into my light weight mostly strip with limited street car. The car has manual brakes and the primary function in bracket racing (stabbing cold brakes at 110-115MPH)
Are the satisfied brake products worth the money?
Since I got out of the brakes so cheaply, I figured if there was an advantage I'd spring for the more expensive pads.
From what I've found out organic pads will work best for me. However they’re usually not the best quality. I'll have to see if I can find a good quality 'cheap' pad locally.
