Island Dragway Great Meadows, NJ.
Track Web Site - Current Weather
Wasn't a good day....
Old Jun 27, 2005 | 07:59 AM
I hate the 1.5 hours it takes me to get to Island.
Especially up all those mountains.
Old Jun 27, 2005 | 09:32 AM
sickt7cuda's Avatar
Mike, compared to me, you had a good day.
I was at Island on Saturday. First time trial was a 1.71 60', 12.26 @ 110. The air was terrible. Second time trial was 1.70 60', 12.18 @ 110.
1st round - I get abour 3/4 the way down the track and the engine starts to break-up - nearly stalled - had to pump the pedal just to keep it from stalling on the return road and drove it up and into the trailer.
Yesterday I pulled off the left head and found 3 broken valves. The mushrooms snapped off the stems and wedged sideways into the seats.
The piston tops have all sorts of gouges from the pounding they took. And atleast 1 cylinder wall has deep scratches.
My guess is there wasn't adequate valve to piston clearence - something my "friend" said we need not check. Of course, it's possible I screwed-up setting the valve lash but I doubt that....I did it 3 times by the book.
I'm really disgusted
Old Jun 27, 2005 | 09:37 AM
Mopower71's Avatar
Administrator
It takes me at least that long to get to LVD. And that's the closest track, 90 miles, and some nice hills.
Sorry about the rough day Mikel
Old Jun 27, 2005 | 10:12 AM
Re: Wasn't a good day....
-.014 RT (red again!), 1.739 60', 12.653 @ 105.36.
I just realized that this was my best 60' time ever. I removed the 1" carb spacer and installed a Hilborn scoop on top of the carb. Finally got some air going into the carb instead of boucing around under the hood.
Congratz on your new best.!! =D>
Old Jun 27, 2005 | 10:20 AM
Dan, New cam new heads and you didn't check clearence?!?!?!?!?
http://www.barbneal.com/wav/ltunes/elmer/Elmer03.wav
Old Jun 27, 2005 | 01:29 PM
  #10
DARTSPORT's Avatar
I don't feel so bad, after reading about some of you're weekends!! Numidia Raceway is only about 14 miles from my home. I didn't break anything!! But it was HOT, 95* to 98* , oxygen altitude was 4450' to 4700' . I had a red light of -.003 , first round. My car kept running faster all day, and going by the weather, it should have been slowing down? First run 10.040et, second run 10.028et, and 1st elimination 9.982et, with a red light. It was that hot, that I didn't mind loosing to much.. A bad day racing is still better than a good day at work!! Sorry to hear about the bad luck Dan!!
Old Jun 27, 2005 | 08:53 PM
sickt7cuda's Avatar
I really thought I could trust the guy. He talks a good talk and I guess it ends there. Thinking back now, I remember him telling me that Paul Newman stopped by his shop one day and wanted him to build an engine for him. He said he told Newman he was just too busy. My radar must not have been working that day, as I'm sure now, it was all BS.
Tony, I had asked him if we should check the clearences and he said it wasn't necessary with that cam. We never even measured how far down in the hole the flattops were, which didn't have any valve reliefs cut either.
I was skeptical, but went along with it. It won't happen again.
Old Jun 28, 2005 | 06:47 AM
  #12
Dan, how deep are the gouges? Can you salvage the block?
Old Jun 28, 2005 | 04:07 PM
  #13
sickt7cuda's Avatar
Tony, I'm sure it could be bored out but really, what's the point? I'm going to need new pistons and rings anyway, so I might as well dress up the 400 block that I have.
This whole thing would be easier to swallow if it happened near the end of the season. It's going to take time to get it done.
Today I pulled the other head off. The pistons had shallow depressions where about 1/3rd of the valve was smacking the pistons. And to add insult to injury....it wiped out the cam. Two of the lifters won't come out from the top; the bottoms of the lifters are flattened out so badly.
So here's the plan: Buy 1 new head (probably cost more to fix)
440 steel crank into the 400 block
440 rods
New pistons - Diamond or Ross
New cam and lifters
CHECK PISTON TO VALVE CLEARENCE!
AND STAY AWAY FROM HERMAN! Wadda ya think?
Old Jun 28, 2005 | 04:58 PM
  #14
Sounds good! But if you going to do all that. Starting from scratch
sort of speak with the block. With new rods and all why not,
(in the words of the immortal Frank Zappa),
"Stroke it"!!!
Old Jun 29, 2005 | 08:45 AM
  #15
sickt7cuda's Avatar
Ah, Frank Zappa....I used to have a poster of Frank sitting on a toilet smoking a joint - it was great.
Actually, it will be a stroker. A 440 crank and rods in a 400 block bored .035 over is a 451ci. That should be plenty for me....for now. I just want to get back in the "game" as soon as I can. I can always change things later on.
Tony, I'm still trying to figure out exactly what went wrong with the motor. I thing it's kinda odd that the 3 valves that hit the pistons were all intake valves. Those valves should have been closed on the compression stroke. Usually, when you see valve to piston contact, it's the exhaust valves that are involved. Any ideas?
Old Jun 29, 2005 | 10:07 AM
  #16
Dan, could your timing chain have slipped or broken?
Old Jun 29, 2005 | 02:54 PM
  #17
sickt7cuda's Avatar
That's sure a possibility (the timing chain). I haven't pulled the engine yet and it'll be alot easier to check that out then. Not that it's any guarantee that nothing could go wrong, but I put a new Cloyes timing set on when I made the other changes.
Old Jun 29, 2005 | 03:00 PM
  #18
That was the only reason I could come up with why the intake valve would be open when it should be closed. That or the cam breaking in two.
Both would stop the valve train from moving, I think
Old Jun 29, 2005 | 05:31 PM
  #20
I don't see any sorry.
Looks good though and proof you were actually there.
Old Jun 29, 2005 | 06:48 PM
  #21
sickt7cuda's Avatar
I can pretty much guarantee that there is air in, over and around the tire, but none under it.
Old Jun 29, 2005 | 07:01 PM
  #23
BBLM23's Avatar
So close...
Old Jun 30, 2005 | 08:35 AM
  #24
If you can slip a credit card under the front tire, that's wheels up to me
Old Jul 4, 2005 | 07:47 AM
  #25
Hey Dan, Was talking to a guy at the track yesterday about what happened to you.
He said it happened to a friend of his one time.
Said the reason for the intake staying open was the valve guide was to tight and bound the intakes so that they could not close.
Old Jul 4, 2005 | 02:44 PM
  #26
sickt7cuda's Avatar
Tony, if that's the case, then Edelbrock may have some quality assurance issues to deal with. I'm not sure that's what happened though.
In that 383 block with flat-top pistons, I've read that a .509 cam is limit without valve reliefs cut in. I had no valve reliefs and my cam had 540/560 lift. The pistons were about .015 down in the hole and the head gaskets were .028 The cam had no business in that engine without the valve reliefs.
BBLM23
Racing Updates
6
May 6, 2007 09:46 AM
Mopower71
Racing Updates
6
Oct 9, 2006 07:47 PM
Racing Updates
12
Sep 24, 2006 05:26 PM
Old Bridge Township Raceway Park
13
Aug 23, 2005 12:57 PM
Atco Raceway
4
Nov 9, 2004 10:11 AM
