New parts.
The car should run oretty good this year. I have a new set of M/T drag radials on the way $300 shipped and I just picked up a transmision. Its got about $3000 worth of work done to it (from what the guy said) 904, low 1st gear, T/A valvebody, transhield and a 8" T/A converter. I also have a set of 3.91s going in it that I got from walter.
Re: New parts.
I got the trans from BossVega's cousin. It was in his 9 second tube chassis Duster. He put the motor in a Tube chassis Daytona and switched to a PowerGlide. I paid $500 for it.
I want to pick up a A@A valve body from Chris though. |
Sounds good Adam.
What about your front brakes :mrgreen: |
Sounds good Adam.
Making progress, got the carb to idle, wired in my killswitch and all my guages are hooked up. Going to pick up the trans tonight.
Have fun =D>
Got the transmission. $3500 to build it. 904 low gear set, T/A valve body, bolt in sprag and a T/A 8" converter.
Tony what converter did you go with ? |
3800 flash =P~ |
The guys I bought the trans from said this one was 3500-3800 but that seems pretty tight for a 8" The T/A site lists a few 8" converters ( not mine though) and there rated at 5500 :shock:
I'll give turbo action a call and see what they say. I here they keep good records of the converters.
Should be fun on the street though. :mrgreen: |
