Tech Racing Tech
Voltage?
Old Oct 24, 2004 | 11:29 PM
BBLM23's Avatar
Re: Voltage?
How much voltage should an alternator put out?
I probably should check it at about 12-1500 RPM.
Yup. Should be around 13.7 but not at idle.
Old Oct 25, 2004 | 04:02 AM
Mopower71's Avatar
Administrator
Re: Voltage?
I thought it was 14.7
Old Oct 25, 2004 | 09:30 AM
sickt7cuda's Avatar
At idle you should have 14-14.5 volts at the battery. Even though the alternator is rated at 60amps, it's probably putting out much less. Check the Amp output at the alternator. 8ga wire is fine, I only run 10ga without a problem and don't use a relay to the battery in the trunk.
If you need to upgrade the alternator, Summit offers the Powermaster 120amp which is great. Their catalog wrongly lists it as 75amps at $160, but I ordered one and it came with a tag certifing it as 120amps. It listed in the Mopar section.
Old Oct 25, 2004 | 09:51 AM
BBLM23's Avatar
Re: Voltage?
What should it be at idle?
Don't bother checking at idle...
Old Oct 25, 2004 | 09:54 AM
BBLM23's Avatar
Re: Voltage?
I have never seen over 14 with the Mopar Performance regulators or the older Chrysler alternators. 14.7 is pretty high for anything...
Old Oct 25, 2004 | 11:42 AM
sickt7cuda's Avatar
Yes, Powermaster does have a 1 wire version in Chrysler trim.
And I am using 10ga with a 120amp alternator. Haven't had any roblems so far. With the 1 wire there is no need for an external voltage regulator cause it's built into the alternator. I should note that I have an underdrive pully on the alternator.
Old Oct 25, 2004 | 09:41 PM
sickt7cuda's Avatar
Roger that. REV IT UP !!!!!
Old Nov 1, 2004 | 10:38 PM
  #13
Mopower71's Avatar
Administrator
I'll give it a shot. Then I should have 14-ish volts?
So What was the voltage when you REVED It Up?
Old Nov 3, 2004 | 12:50 PM
  #16
http://www.iequus.com/assets/manuals/tge.pdf
Hope that helps.
proe305
4
Jul 12, 2006 11:02 AM
17
Feb 11, 2005 07:21 PM
Oct 31, 2004 02:42 PM
21
Aug 15, 2004 10:21 PM
Engine/Chassis/Race Car Builders
12
Aug 4, 2004 09:44 AM
