Old Bridge Township Raceway Park Englishtown, NJ.
Track Web Site - Current Weather
Mopar Nats Saturday 5-14-05
Old May 14, 2005 | 08:03 PM
Beautiful day mid 70's and sunny.
I Had a great time. Met up with Mike(Mikesduster) and met his father. Second time seeing Mike. Mike and his father are great people.
Ok here we go. First run off the light the motor broke up. Found a loose wire and cleaned the baterry posts. Problem gone.
Second Run I left at 2800 no tire spin cut a .043 light and ran a new best
60' 1.896 and a new best 1/4 13.007 @ 104.02
Third run I ran a I left @ 1800 bad light .352 and spun the tires pretty good 13.575 @ 102.86.
Fourth run 1st elimination I dialed in @12.95 instead of 13.05 I was determined to get into the 12's. I also put the 6700 chip into the MSD 6al.
Left @ 3000 .262 light and shifted @ 6400 ran a 13.016 @ 105.34. I lost by .0543.
All in all I had fun. My friends had fun busting my chops and it was a beautiful day.
Next time out I'm gonna play with the timing a little.
I'm also starting to wonder if I got all the head work I paid for
Old May 14, 2005 | 10:06 PM
Mopower71's Avatar
Administrator
Congrates on the new best =D> , Glad you had fun
Old May 14, 2005 | 11:43 PM
sickt7cuda's Avatar
Tony, glad to see you had a good day. I spent the day putting down mulch Anyway, you're knockin on the 12's, and with some more tuning you'll be there soon. How many RPM's were you turning at the stripe? And was that on the street tires or slicks?
Old May 15, 2005 | 11:38 AM
Did the mulch thing last weekend. My back was sore.
6000rpm at the stripe. this was on M/T drar radials. They really bit.
Old May 15, 2005 | 11:40 AM
TomMonte's Avatar
Cool, sounds like you had fun!
Old May 15, 2005 | 01:56 PM
fastbackcuda's Avatar
I would think you should be turning more then 6000rpms threw the traps with 4.30s and a 26" tall tire
Old May 15, 2005 | 03:58 PM
So what do you think?
Old May 15, 2005 | 05:37 PM
This is my losing 1st elimination run. Lost by a hole shot
Thanks for linking me up Mikel
https://www.northeastbracketracing.c...s/MVI_0016.AVI
Old May 15, 2005 | 06:57 PM
kruger's Avatar
Same here Tony..
Old May 15, 2005 | 07:01 PM
  #10
Same here Tony..
Ok then thoughts on why I am not?
Old May 15, 2005 | 09:09 PM
sickt7cuda's Avatar
Well, RPM's through the traps are also dependent on your cam profile. What are the specs on your cam, Tony? I know you also drive on the street, so I'm assuming you don't want to get too aggressive to keep it streetable, right?
Old May 16, 2005 | 06:35 AM
  #12
I have comp cam ex274
Old May 16, 2005 | 09:12 AM
  #13
230/237 .480/490 110 LSA
I would think this cam would want to be pulled to 6500-6800 rpms.
Old May 16, 2005 | 01:54 PM
  #14
TomMonte's Avatar
Comp's catalog shows the operating range as 1800 - 6000. I have a much bumpier cam and I shift at 6500, through the traps at 6700+.
Tom
Old May 16, 2005 | 02:33 PM
  #15
Tom
If thats the spec on the rpm's of the cam maybe my problem is over rev the shift points.
Think I should shift @ 5800 to stay in the power curve?
Let 3rd gear take me home?
Old May 16, 2005 | 02:42 PM
  #16
TomMonte's Avatar
Have you ever tried shifting at 6000? When you shift at 6400, does it continue to pull, or does it feel like there's a slight loss in momentum? When you hit it just right, you'll know...it's like butter.
Tom
Old May 16, 2005 | 02:49 PM
  #17
Have you ever tried shifting at 6000? When you shift at 6400, does it continue to pull, or does it feel like there's a slight loss in momentum? When you hit it just right, you'll know...it's like butter. Tom
I noticed in another vidio of the same day it nosed down at a 6400 shift point and then came back up after the shift.
Old May 16, 2005 | 07:47 PM
  #19
Damm
did you factor in 3500lbs with me in it?
Going through the traps at what rpm?
Old May 16, 2005 | 07:58 PM
  #21
Thanks again Mikel.
I'll get there sooner or later. Prob just in time for the rebuild
Old May 16, 2005 | 08:16 PM
  #22
Time to put the car on a diet. Loose the heat, all that radio stuff in there and that sway bar.
Mopower71
Racing Updates
6
Oct 9, 2006 07:47 PM
onehellofadart
2
May 23, 2006 01:42 PM
Island Dragway
25
Jul 4, 2005 02:44 PM
onehellofadart
Island Dragway
3
Sep 7, 2004 12:40 PM
onehellofadart
2
Aug 30, 2004 02:00 PM
